For A Free Quote
Call Now
(705) 999-0197
Whether you have asphalt shingles, cedar shake or something else. Chances are we work on them!
Roofing Shingles - know the benefits of installing asphalt shingles.
Roof installation becomes priority one when you find that the existing roof of your home has become old and damaged. Hence, you will need to explore the different options when it comes to replacing the roof and the best option for you is to consider roofing shingles. The careful selection of the roof is very crucial because it is an expensive home improvement project that requires a considerable amount of investment. Therefore, you will need to look for a roof that will last for few decades so that you don’t need to replace the roof in near future.
Benefits offered to Barrie residents by using roofing shingles
Roof Repair
The right choice of roofing system in Barrie, ON identifies the visual appeals as well as resilience of the roofing system to ensure that your residential or commercial property will be safeguarded from the different weather. It likewise makes your residential or commercial property look appealing as well as visually attractive as well as thus you ought to search for the most dependable, gorgeous as well as economical roofing system for your house.
Asphalt shingles
Asphalt shingles is thought about as the most prominent as well as extremely sought roof choice since it is offered in
a variety of colors, textures and styles that you can choose from. The reason for the popularity of these shingles is due to its overall charm, longevity and resilience that is far more exceptional as compared to the other roofing options.
Lifespan of asphalt roofing shingles
The expected lifespan of the asphalt 3-tab shingles is about 20 years while the architectural shingles can last for about 30 to 50 years. This is the reason why majority of the property owners choose this option because it can last for many years without any major maintenance or replacement schedule.
Benefits of asphalt shingles
Environmental friendly.
The benefits of using roofing shingles for your home is that it does not add to the landfill space as you can recycle the shingles. The reason for this is because it is made with composites that does not cause any harm to the environment and you will get the most environment friendly roof in Barrie, ON.
Reduced energy consumption.
Another benefit of using asphalt shingles in your home is that it helps in decreasing your cooling and heating requirements. This will help in lowering your energy bills so that you can save money on heating and cooling costs in the long run. It is also an energy efficient roofing option that will provide highest level of insulation to your residential or commercial property so that you will delight in a cooler home in summer and warmer home in winter season.
Flexibility.
Choosing asphalt shingles can be the best option for your home because it can be installed and maintained easily without any kind of issues. You can select from the wide range of options that are available for home so that you will start enjoying its benefits with easy installation process.
Does your Barrie home need help with Asphalt or Cedar Shake shingles?
If you want to get any information relating to roofing shingles and its installation then feel free to contact us for all kind of assistance and guidance. We offer a wide variety of services in Barrie, ON for residential and commercial properties so that you will get the best roof that you need for your property.
Get A Free Quote!
